17" ORP tires and wheels on 2wd
Old 03-18-2002, 12:30 AM
RedTruck's Avatar
Question 17" ORP tires and wheels on 2wd
Hello, I have a question or two about a 2wd with the 17" ORP wheels. What size and brand are everyone running on a stock height truck? My truck is a 99 and came with the 255-70-16s (3.55 non-LS), will I have to get the speedo gear changed to run these wheels? Just got a set and I am trying to figure out which tires to get. Can I run a size bigger than what Ford puts on the 2wd trucks with these wheels with no change to the speedo? Thanks for the help!
Old 03-18-2002, 12:55 AM
V6runner's Avatar
99 and above will need reprogramming by dealer about $50-75 for tire size change. I am running 265/70R17 on a reg.cab. and do not rub under any conditions.
Old 03-23-2002, 09:13 AM
2fords's Avatar
http://www.miata.net/garage/tirecalc.html
I have 275/60/17 on my 2wd sport and using this tire calculator our diameter is pretty close. I don't believe you would have any problems just bolting the 275/60/17 on.
Old 03-23-2002, 09:15 AM
2fords's Avatar
BTW, 275/60/17 is the stock size for mine.
Quick Reply: 17" ORP tires and wheels on 2wd
