lightning rims rubbed with34drop fix
Old 02-24-2002, 08:20 PM
mr2x75's Avatar
i just put 99 lightning rims on my 2001 f 150 ext.cab they rubbed when you turn the wheel all the way in, They rubbed on the brake line bracket bolt. How I fixed it was to place the bracket on the inside by doing this I had to grind about a 1/4 inch off the threads so it would fit between the lip on the bottom a arm, and simply bolted every thing through the back side of the same hole. becarefull to not take to much off the bolt so you will have somthing to thread in. I put everything back together and nothing rubbed.
dale [mr2x75]
Quick Reply: lightning rims rubbed with34drop fix
