tire rubbing
Old 02-22-2002, 02:09 PM
borloco's Avatar
tire rubbing
does anyone have problems with tire rubbing with bigger tires?
I have 33x12.50 with a 6 inch lift
Old 02-22-2002, 03:35 PM
mthunwardsen's Avatar
No problem. I don't have any lift other than the little bit extra body lift on the Off-Road 4x4 package, so with a 6" lift, you should have absolutely no problems. I just got some ProComp 33/12.5R17's on mine. I had a little bit of rubbing on the front fenders. It was on the lower portion of the vailance fender (plastic anyways). I just shaved the plastic off, but you can't tell at all. You probably could fit 35"s without any worries. Good luck!
Old 02-22-2002, 04:47 PM
rtroha's Avatar
Thumbs up No problems here.
I've got 7" of lift and I am running 35's with no rubbing at all. I'm thinking of going to 37's when these start to wear.
Bob
Quick Reply: tire rubbing
