Shuddering Brakes
Old Jun 12, 2019 | 12:20 PM
Arod1023's Avatar
Shuddering Brakes
Hey folks newbie to this great site .i have a question that probably you experts can help me out with .2008 f150 fx4 has some shuddering so I replaced my rotors and pads and slide pins and re assembled .shuddering has not gone away .chexked my wheel bearings as well and no play Was wondering if you guys had any ideas ? Was going to replace rear brakes and possibly upper and lower ball joints any help would be greatly appreciated
Old Jun 12, 2019 | 02:42 PM
When does it start shuddering? When accelerating, braking or coasting?
Old Jun 12, 2019 | 03:49 PM
Arod1023's Avatar
When i am braking
[QUOTE=ManualF150;5251382]When does it start shuddering? When accelerating, braking or coasting?[/QUOT
Old Jun 12, 2019 | 03:55 PM
I would check your rotor's runout.
Old Jun 12, 2019 | 06:07 PM
Arod1023's Avatar
Run out is 2000 so I think it’s ok . I was going to replace my bearings?
Old Jun 12, 2019 | 06:27 PM
Usually pulsation through the brake pedal is indicative of warped rotors. However, depending on the severity, you may not feel it.
Can you take a picture of both sides of the rotors?
I really don't think there is anything mechanically wrong with your truck.
Old Jun 12, 2019 | 09:54 PM
Arod1023's Avatar
The rotors are brand new and not china
Old Jun 12, 2019 | 10:00 PM
Roadie's Avatar
Check the tie rod ends.
Old Jun 12, 2019 | 10:18 PM
You sure the ABS isn't kicking in?
Old Jun 17, 2019 | 12:43 AM
JackandJanet's Avatar
Arod - I moved your issue to its own new thread, since it has nothing to do with the problems posted in the other 11-year old thread.
As glc suggested, you MAY be feeling the ABS engaging. Sometimes, it can seem a bit overactive in my opinion. If the rotors aren't warped, there's little else that can cause what you are experiencing. I certainly wouldn't think this would be caused by faulty bearings.
- Jack
Old Jul 1, 2019 | 01:11 PM
Fbird's Avatar
are you using ceramic brake pads?......i too had similar issues when using ceramics up front.... even after I cut the rotors...3 weeks later...same thing...more like BITING...not ABS pulsing. Went to semi-metalic front ceramic rear.. seems to work
