Drag Radials on 2014 F150
Just an FYI. A 305/45R18 Mickey Thompson ET StreetR will fit on a stock 18x7.5 wheel that's been widened 2". I just had to remove the upper shock dust covers and use a 1/4" spacer that I got from Rough Country. Had the wheels widened by WeldCraft Wheels out of Michigan; they did a great job on them.
You wouldn't even know there was a drag radial on there if you weren't looking for it.
Haven't been able to dyno it or get it to the track yet, but it appears to be trapping somewhere in the 105-107mph range in the 1/4 when running at Da Pad. So on this tune probably in the 450-480ish range at the wheels. I have a Killer Chiller here to put on also. Once it's on I would expect to see about a 40ish rwhp jump. It pulls out a lot of timing due to heat. Plus I can put the bigger tune in then, which I'm hoping is about 550ish at the wheels.
