Which of the two will fit?
2014 F-150 2.5" AS leveling kit
Method NV 18X9 wheels
Offset: 18mm Backspacing: 5.71
I'm looking at these two choices in tire..I want the BFG because of the old school look of the raised white letters, but I think they're too wide...
BFG All Terrain KO2
35x12.50R18/E Diameter: 34.5 Width:12.5
Nitto Terra Grappler G2's
LT295/70R18 Diameter: 34.29 Width:11.77
BFG All Terrain KO2
https://www.customwheeloffset.com/wh...it-custom-rims
From the same website, he's using wheels with the same specs and 33's fill it out just as well and leave more clearance for the tire when going over big bumps with the wheel turned.
And this one too...guess I'll stick with 33's
I'd really like to stick 34's on there...
SO I picked up a set of KMC Brodies, 20x9, the offset is 30mm, and backspacing is 6.18. I was hoping to fit Cooper STT's. They're 35x12.50 but the actual diameter is 34.65 and the width is actually 12.....
I've read where several people have run tires that size with a 2.5 kit and minor to no plastic trim, with no metal trim...I think I might try. Won't be til late in the fall probably though.
