What torque for lug nuts on 2001's?
Help! Does anyone know where to find the torque specs for the lug nuts? I just rotated my tires on a 2001 Supercrew with stock, 16", aluminum wheels. I spent 2 hours looking on the web and in my owners manual with no luck. I don't want to undertorque them and have the wheels fall off, or overtorque them, stretch the studs and warp the brake rotors.
Thank You, Thank You, Thank You
I love this site. Thanks for the quick response. I was getting all bent out of shape that this information wasn't stamped on the wheel or in the owners manual. After reading the responses I looked and sure enough, the plastic card with the jack(which I was not using) says "torque to 135-160 ft-lbs - see spec". There is no spec.
But, just like 01sport says, it is stamped on the lug nut itself! My lugs are a 2 part lug - the lug nut and an attached washer. The tiny lettering on the washer says "150".
Sorry for wasting your time guys - I was doing this in the rain, it was overcast and dark and I didn't see it.
I too looked for that info with no luck. Actually downloaded the PDF version of the owner's manual and did key-word searches -- with no luck.
Funny, since with my '97 Ford had a recall due to the stupid lug nut design -- so I just KNEW that they'd have mentioned torque a zillion times with the subsequent year vehicles.
I've got the steel wheels, and am about to rotate them again -- so I'll get my magnifying glass and go review the jacking instructions -- thanks to 01sport.
