Strange Bounce @ 42 MPH?!?
2002 FX4 Scab - Strange Bounce while braking as truck slows down through 42-41 MPH...I thought it was an out-o- round tire, but just put new Nitto's on last week and it's still there. Before the new tires it would bounce without braking at 42-41 MPH, now not so much - Any Ideas? Bent Rim? Warped Rotor?
the only thought I have is actually transmission... does it downshift when you cross that speed and the transmission is making it hop?
Maybe repost this in that forum and see what they say.
There is nothing I can think of in the brake system (except maybe an ABS fault, but highly unlikely) that would be speed dependent like that.
Its like the truck is riding on "basketballs", for maybe 2 seconds when I brake, and only as it slows down from around 43 to 41 mph, then all is normal. In other words if I'm traveling at say 55 mph and begin braking, all is normal until the truck slows thru the 43 to 41 mph range, then the truck bounces until it slows below 41 mph, then as I continue to brake, its back to normal as the truck slows from 40 mph on down to 0. The 43 to 41 mph bounce while braking occurs no matter how hard I brake, only the duration of the bounce changes with how hard I brake - its so stinking weird.
