33x12.50R17 on V6 truck?
Got an opportunity to get my hands on a set of 33x12.50R17 Mickey Thompson Baja Radial MTZ's for a screamin deal. BUT, my truck has the puny 4.2L V6 under the hood. It's a 2WD as well.
I don't think the motor has enough ***** to run tires that big and gnarly.
I presently have 265/70R17 Dunlop Rover AT's on the truck, which are already plus sized from the OE 235/70R17's that came on the truck from the factory.
Thoughts?
Thoughts?
Which is really too high. His stock gears and tires are probably around 18-1900 at 70. 33s would lower that further. Anything over 2000 is just too high at that speed. It will do nothing but waste gas on the highway.
And my 5.4 turns 18-1900 at 70 with a 3.73. I see no reason why yours should turn that high. It is basically the same engine with less cylinders. Yours is even a 3.55 which should be less rpms. Or your 2250 number for 4.56 is way low. That would be an increase of almost 25% on the rear, but a less than 10% on tire diameter. Stock being 30-31" going to 33". In that case the rpm would be a good bit higher than your 2300 rpm.
Here is a good place to check out the numbers. Put in any size tire and gear ratio you want.
http://www.csgnetwork.com/multirpmcalc.html
