Rim width
Old Jul 5, 2013 | 04:53 AM
BradleyM91's Avatar
Rim width
I want to get 33x12.5x17 toyo open country m/t on my 05 f-150 stx 2wd with a 2.5" level what would be the smallest rim width I could get that would safely hold these tires? Could I use a 17x9/6x5.5 or would I need to go with a 17x10/6x5.5?
Old Jul 5, 2013 | 10:12 AM
pizzaman711's Avatar
You can use down to a 8" wheel and be fine. And your bolt pattern is 6x135mm not 6x5.5.
Old Jul 5, 2013 | 12:09 PM
jdeacon's Avatar
this. i did run 12.5s on a factory 7.5 wheel, but i really just didnt like the look of it. a 9 inch wide wheel sounds perfect
Old Jul 5, 2013 | 12:30 PM
wandell's Avatar
You can fit that tire using the stock 17x7.5's. Since you have a 4x2 (with a leveling kit) for an aftermarket wheel, I'd look for an 8 inch wide wheel with 5.5 or 5 inches of backspacing. If you use a 9 inch wide wheel, I think you are gonna need more lift.
Old Jul 5, 2013 | 12:53 PM
BradleyM91's Avatar
Thank you for the help guys! Y'all have given me a lot more info then the tire places around where I live.
Old Jul 9, 2013 | 02:44 AM
BradleyM91's Avatar
Thanks to the help from you guys I now have my new wheels and tires on the way and should be here Friday afternoon I will post pics when I get them on I decided to go with 17x9/6x135mm ballistic jesters wrapped in 295/70r17 nitto trail grapplers. Come to find out toyo owns nitto and the open country m/t are the same tire as the trail grappler even made in the same factory with only slight variations in side wall tread
