Wheel Spacer Opinions...
Old Apr 5, 2013 | 03:40 PM
_89F150's Avatar
My apologies if this is a topic that's been talked about a lot on here.
Anyways, I am looking to make my stance just a tad bit wider with maybe 2" spacers. I
Any haters or likers out there? I've heard numerous people say they screw things up and also heard numerous people say they don't cause problems like people say they do. I understand they wear out ball joints quicker but any other problems I should be aware about? I mean, I work 3 minutes from home and I don't drive like a maniac so I'm not sure if that makes a difference.
My truck specs if needed:
89 F150 Reg cab LB
Lifted 9", 4.11 gears
Not straight axled
Any help is appreciated. Thanks
Old Apr 5, 2013 | 05:17 PM
pizzaman711's Avatar
What are the specs on your current wheels?
Old Apr 5, 2013 | 05:27 PM
_89F150's Avatar
Sorry,
18x10 Moto Metal 962 -24mm
325/65/18
Old Apr 5, 2013 | 06:30 PM
Your wheels are already at 4.5" of backspacing, so adding a 2" spacer would be like having a wheel with 2.5", your wheel bearings are going to hate it. Personally I wouldn't do it for that reason alone, not including all the potential safety hazards.
I'd go with either a wider tire or a wider wheel and tire combo to get them to look wider.
Old Apr 10, 2013 | 12:34 PM
Lifted5.4Lariat's Avatar
With the offset you already have I wouldn't do it. But, if you're dead set on it only get ones that are hub centric. Meaning the adapter has an extended lip to keep it balanced and reduce the risk of vibration and potential problems.
Old Apr 10, 2013 | 01:14 PM
And the ones that have new studs pressed in, and in this case cheap isn't always better.
Old Apr 10, 2013 | 01:48 PM
Nope it sure isn't. Id say expect to spend at least 3-400 for a good set.
Old May 4, 2013 | 09:15 PM
blackmomba's Avatar
ive been running them on my f150 for months now as long as you keep them torqued and check them youre fine thats what i do and no issues at all i had rubbing issues on my f150
Old May 6, 2013 | 12:14 PM
wandell's Avatar
I wouldn't do it.
