Largest tires on a 4x2
Old Aug 16, 2001 | 10:11 AM
plancha1's Avatar
I want to stuff some 255x85/16's on my 2000 f150, 4x2. Will these 33" tires fit without rubbing? If not what can I do to help them fit, aside from a lift kit?
Old Aug 21, 2001 | 06:34 PM
Lou Colmo's Avatar
Smile
I put on P265/75R/16's, Filled up the wheel wells nicely, no clearance problems.
Old Aug 27, 2001 | 01:17 PM
Jolly_Green_Giant's Avatar
I had my new tires installed two days ago. I put on 285/70 R16's.
The tire type is BFGoodrich All-Terrain AT Ko
There is a slight rubbing when the wheel is turn hard over left. Other than that I haven't had any troubles with rubbing even on 5 inch deep dips at 35 mph. Havn't had them out in the wilderness "yet".
Old Aug 28, 2001 | 09:51 AM
plancha1's Avatar
Max-
Thanks for the input. I am actually going for just the opposite. I want to go for the tallest wheel that I can stuff in my wells. I also want to keep the same width, maybe even go a little more narrow (for mud traction). I appreciate the info, though.
Old Aug 28, 2001 | 11:53 AM
dwdodd's Avatar
I have a set of daystar spring spacers I don't need if you are interested.If you want to find out more about them run a search for SPRING SPACERS , you will find all the info on them
