Offset Question
Old Aug 5, 2012 | 07:56 AM
klhmn's Avatar
Offset Question
Ok been looking at adding some new Nitto Terra Grapplers and ATX Ledge wheels, I want to keep the same diameter but a bit wider. The Ledge Wheels come in a +0 and +35 offset, is it safe to assume the +35 will stick out 35mm than the 0 offset?
I am looking at this tire size 305/60R18 120S.
Does anyone have any pics of the 2 offsets to get a visual?
Old Aug 5, 2012 | 09:22 AM
atr04screw's Avatar
The less offset a wheel has, the more it will stick out. The +35 is very close to your stock wheels offset, so they will stick out about as far as stock. The 0 offset wheels will stick out about 2 inches further than stock, so if you want the wider look then you will probably want to go with those.
Old Aug 5, 2012 | 11:08 AM
+35 offset, unknown tire size.
0 offset, 33/12.5 ( 305/55 tire )
Sticks out maybe an inch and a half more than the +35. Looks much better though.
Offsets will vary depending on your wheel width.
This guy has some good angle photos of 0 offset.
https://www.f150online.com/forums/3880128-post5.html
Old Aug 6, 2012 | 06:41 AM
klhmn's Avatar
Thank you very much for the visual!
