MAX Tire size on an 18" rim
Old Jul 16, 2012 | 01:57 PM
marklar89's Avatar
Hi,
I've got a 2012 FX4 on the way and was curious about the max tire size. Can 33" tires fit on the truck without a lift?
Old Jul 16, 2012 | 02:03 PM
MossyOak3006's Avatar
Originally Posted by marklar89
Hi,
I'm not positive, but I think so. You may want to get 33x11.50 to avoid minor rubbing. You can put a 1.5 or 2" leveling kit on and fit 33x12.50s with no rubbing
Old Jul 16, 2012 | 02:32 PM
atr04screw's Avatar
Yep, 33s will fit on a FX4 with no lift, and I assume you are talking about stock wheels. The only way you might run into problems is if you are running aftermarket wheels with a really low offset.
Old Jul 16, 2012 | 02:46 PM
marklar89's Avatar
Yep i will have stock rims.
Old Jul 16, 2012 | 08:58 PM
BRUTE448's Avatar
hey mossy oak..I have 18x9 xd monsters and will be doin toyo MT 33/12.50 when my kellys wear out..i was think I might be able to stuff 33's w/o rub before I level..am i thinking wrong?..i plan to level just not sure when
