hub centric rings
Old May 14, 2012 | 11:53 PM
Tomshoes69's Avatar
hub centric rings
Does anyone have any information on hub centric rings. I wanted to order a set however how do I know what size to use. Does anyone know the hub diameter on a 2012 super crew platinum. I have after market wheels, lug centric, wanted to put on some of these rings but have no idea what size to get to fit on the f150?
Old May 15, 2012 | 02:03 PM
Cash@TireRack.com's Avatar
Former Sponsor
You will want to contact the retailer that sold you the wheels. They should have the center bore for the wheels you purchased. The centering ring you will need will need to snap into the back of that wheel and fit on your 87mm center bore of your truck. Most hub centric truck wheels come with both Ford and GMC centering rings in the box. Normally, if the wheels are lug centric, the use of centering rings is not needed as the name implies - the conical lug hardware centers the wheel onto your hub assembly.
