Bled Brakes to Change Fluid - now ABS light is on
Old Mar 24, 2012 | 06:16 PM
OwnerCS's Avatar
This afternoon I started bleeding the brakes to change the brake fluid. After bleeding one wheel for a while, I had to stop the job to make a quick trip. As soon as I started the engine the ABS light was on and and emergency brake light. The emergency brake light eventually went off. However, the ABS light will not go off.. I will continue bleeding the brakes tomorrow but I wonder if some air entered the ABS modulator somehow.
I'm not familiar with the type of ABS unit on the 95 2wd Flareside 5-MT 4.9 L engine.
Final Update -
I let the truck set for about an hour -- then drove it again and the ABS light was off.. So everything returned to normal after a drive and letting it set a while..
Old Mar 25, 2012 | 10:21 AM
BLUE20004X4's Avatar
Good deal man, I was going to say I've had some ABS bleeds that took forever to bleed. Keep in mind you might have a bad wheel cylinder in the rear where I believe ABS is only on the rear brakes.
