2010 Harley Davidson F150 Wheels
Old Mar 21, 2012 | 09:33 PM
rayofsi's Avatar
Do any other center caps work asides from the original one?
Old Mar 22, 2012 | 03:22 PM
ab46501's Avatar
F150 Limited wheels are the same but with caps that say Ford.
The bolt pattern is the same on all wheels and I have seen different caps swapped on OEM 18's and 20's. So I would guess it is possible that another cap would fit but I don't know how it would look?
Old Mar 23, 2012 | 12:22 PM
mkosu04's Avatar
as AB said... the bolt pattern is the same on all the wheels. The bolts are what the center cap snaps on to, so that should fit.
So then it is a question of the outside diameter of the center cap... are they the same? Time to get a tape measure out.
And then there is the question of whether they would look good. My FX4 center caps have a pattern that distinctly lines up with the wheels.
