what size leveling kit do i need
Old Mar 16, 2012 | 07:00 PM
worldburrito45's Avatar
i have a 2011 Supercrew 4x2 and plan on leveling it eventually (when my tires are done). i plan on getting ( http://www.kmcwheels.com/wheels/?whe...=3&groupid=36# ) in the 18x9. what would be the biggest size tire i could put on there. also how does a leveling kit affect the way the truck drives
Old Mar 16, 2012 | 10:36 PM
jerrybizzle's Avatar
2 inch level and I wouldn't go much bigger than 285/65/18(nearly 33s) with the 0 offset of those wheels. They will stick out an inch or two more than stock. Leveling kits don't affect ride much at all. Mine didn't change.
Old Mar 17, 2012 | 12:18 AM
im real new to this but what is 0 offset
Old Mar 17, 2012 | 12:46 AM
Well if you have stock 18s they are 7.5 inches wide with +30 or so offset. This is a measurement in millimeters with a 5.5 or so measurement in inches of backspacing. So with the wider rims with less of an offset and probably 5 inches backspacing, you have to figure the difference to see how much they will stick out. Easy way to think of it with nine inch wide wheels is that +30 or more will tuck in similar to stock and-12 will stick out significantly. Varying degrees in between with different offsets. It it's fairly complicated. Maybe someone will have a link our explain it better where it will make more sense. Those wheels appear to be offered in only one offset for that size. Other wheels have multiple offset options.
