*whats the correct psi for nitto grapplers?*
Old Mar 5, 2012 | 08:59 PM
Bigboytoys's Avatar
Btw, I lowered the psi to 50
Old Mar 5, 2012 | 09:06 PM
kingfish51's Avatar
Originally Posted by Bigboytoys
Thanks for the info kingfish51, I have a good understanding now
You are quite welcome.
Old Mar 6, 2012 | 04:50 PM
Bigboytoys's Avatar
Kingfish51, I have one more question for ya, am about to tow a 6,500 lbs trailer. What psi should I run with those tires?
Old Mar 6, 2012 | 06:15 PM
kingfish51's Avatar
50 should still be good, but if you get any sidewall flex, bump them up 5-10lbs. I assume you are using a WD hitch, so it should be all the way around.
Old Mar 6, 2012 | 11:49 PM
Bigboytoys's Avatar
Ok, will do, thanks
Old Sep 18, 2019 | 11:17 AM
Matthew Rhead's Avatar
Terra Grappler G2's PSI
I just called the Nitto to verify the recommended PSI to run these tires.
I have a 2012 F-150 Platinum. My tire size is 12.5x20x35. They recommend 37PSI in both the front and back. I hope this helps.
Old Sep 18, 2019 | 12:30 PM
I think this was solved 7 years ago.......
