tire and rim packages
I was looking up tire and rim packages and I found these sizes for my truck,I sill have original tires on truck. I just may move up a size too 275/65R-18 instead.
Here are the sizes they gave me for my 09.
Falkin 245-45-18
235-50-18
225-45-18
Sunny 215-35-18
THANKS JOE
P.S....
I can use some help if anyone else has done the same.
Falkin 245-45-18
235-50-18
225-45-18
Sunny 215-35-18
THANKS JOE
P.S....
Well, you didn't really ask a question, but are you looking to stay stock size, or smaller/larger than stock? Is the trucked lifted/lowered and how much? Of the tires you listed, they are all way smaller than stock and would look tiny. If you are looking for a tire slightly larger than stock, but to fit with stock suspension, then yes, a 275/65/18 is a good size.
Those are all way too small. If 18s 285/60/18 would be the smallest tire for a 2wd I would go. 45 or 50 series will be way too small. Let us know if u are 2 or 4wd and if u plan on leveling, want similar to stock size or want the biggest that will fit. THE 275/65/18 would be the only ones that would look good on your truck.
That size would fit an accord, by no means would look good on an f150. Wild that site recommended that for a f150.
