Tire pressure question
Old Oct 12, 2011 | 10:39 PM
ErikShockey's Avatar
I just got new tires put on my truck and I felt that the tire shop didn't put enough pressure in them. They only put 35 PSI in them.
My truck is a 2002 F150 FX4 single cab short bed. (5.4/4WD)
The tires are Cooper Discoverer ATR LT265/70R-17/E1 121R
http://www.discounttire.com/dtcs/fin...=TCNINT&cs=265
After doing a search on here I went ahead and put 45 PSI in them, but would like to know what is correct for my truck. There is no minimum pressure rating on the sidewall, only max. Thanks!
Old Oct 12, 2011 | 11:22 PM
97forlife's Avatar
whats the max? usual tire pressure is 35-40
Old Oct 12, 2011 | 11:36 PM
80 PSI is the max. When I left the tire shop I could tell they didn't have enough air. With 35 PSI they were very squishy.
Old Oct 13, 2011 | 02:59 AM
spencerdrewh's Avatar
Between 40 and 45 should be fine for you. If you do a lot of hauling then you could run 50-60 depending depending how heavy the loads are.
Old Oct 13, 2011 | 03:22 AM
rcain1us's Avatar
What does your door sticker say? I only have a 2wd with 23570r17 hankooks I run them at the 38 PSI suggested on the sticker
Old Oct 13, 2011 | 08:48 AM
kingfish51's Avatar
It does not matter what the sticker says as he changed the load range of tire that came on the truck.
On your Coopers, 45 should be fine for an unloaded vehicle. Do not go below 45. When loaded, I would put them up to 50.
Old Oct 13, 2011 | 09:18 PM
Thanks for the replies everyone! I will keep them at 45 PSI.
