Will 295/60/20 fit on stock height 2005 kr screw?
Almost 34 inch tire. Probably will have some rubbing, but if you are getting a level soon you should be okay. Do you know the offset of the wheels? If negative it may cause them to rub worse. Should be okay after level regardless, so if u have issues they will be temporary. Assuming you are 4wd.
