Brake Pedal Goes to Floor, I Need Help.
In Thread:
https://www.f150online.com/forums/wh...ml#post4588616
I describe my problem. As I say there, maybe my brake booster is worn and moving so that my pedal goes lower than it should.
I wonder if anybody out there has a similar E or F series van or truck and can help me. If there is, could you have someone watch the end of the master cylinder while you press the brake pedal with the engine running. I'm hoping yours does not move at all.
My MC moves. Not much, an average of three measurements with the engine running gave 0.0128 inches. Not much but looking at the mechanical advantage of the brake pedal, I'm hoping this is too much and I need to replace the booster.
An image of the area I am talking about is at:
http://www.f150forum.com/attachments...r-cylinder.jpg
Thanks In Advance,
Pete
Thanks In Advance,
Pete
Yes I did by building a bypass. But first I would suggest you make sure your rear brake self adjusters are working. One of mine was broken and I am sure that contributed to the problem.
Anyway, I started a thread on another forum. I don't know if it is a violation of "netiquette" to post a link to another forum but here goes:
http://www.fordforum.com/forum/gener...s-floor-24307/
There is also a spreadsheet at:
http://home.roadrunner.com/~pjcalins...asurements.xls
where I posted a picture of what I built. I was also making readings about how far the Master Cylinder might be moving. They are shown but it was a red herring.
The spreadsheet has a second worksheet showing what it cost me. The column "Dan" is what I had to reimburse my son.
Hope this helps,
Pete
Hope this helps,
Pete
I guess I'll never know. I believe the first replacement MC was bad. I couldn't get pressure. After installing the bypass I still couldn't bleed the system. I must have run three quarts of fluid through the system before I finally got pressure. With the first replacement MC being faulty, by the time I got that replaced I had so much air in the system it took many bleed cycles to get the air out. By then I had installed the bypass. I believe that if the ABS was still in there I would have filled it with air and it is really impossible (I believe) to properly bleed an ABS without the computer.
That is why I started by saying make sure your rear brakes are adjusted properly. You need to be an old coot like me to remember before self adjusters and adjusting brakes everytime you changed the oil.
Yep i snugged the rear drums up adjusters before all the bleeding. Everything is brand new and working tho. Calipers rotors pads drums shoes slave cylinder whole new drum kits in the rear with new adjusters and break lines master cylinder and brake booster. So im basically on my hands and knees hoping this works lol.
What did you use to tie the 2 front brake lines together? Just a T? Wondering how to go about it since they are two different sizes.
Here is a link to the spreadsheet with some explanations:
http://petecal.co.nf/VanABSBypass/PedalMeasurements.xls
Here is a larger picture:
http://petecal.co.nf/VanABSBypass/vanbrakes11Crop.jpg
And one with the ABS side by side:
http://petecal.co.nf/VanABSBypass/vanbrakes12CROP.jpg
Finally, I decided I wanted to fix up the wiring so the ABS light wasn't on so:
http://petecal.co.nf/VanABSBypass/ABSCircuit001.jpg
Hope this helps.
Pete
Last edited by PeteC; 09-01-2017 at 10:09 PM. Reason: My host took away my page so I needed to change the links
The line that is closer to the booster is the Primary Circuit... it feeds your front brakes (on a truck, cars are usually diagonal split systems)
The line at the "front of the cylinder" is the secondary circuit... it feeds your rear brakes.
the "long nut" on the secondary circuit is a Proportioning Valve (AKA Prop Valve) and it does indeed reduce the pressure to the rear brakes. Not all vehicles have one... some have the prop valve on the rear axle and it controls the pressure based on the weight in the truck. Newer vehicles just use ABS/ESP/Traction Control to keep the rear brakes from locking up.
"Proportioning Valve", right, I just couldn't get that to pop into my head last night.
On my 1999 150 Van the line on the MC for the rear brakes (including the Prop Valve) is near the boaster and the line on the MC for the front brakes is near the front of the MC.
I just took a look.
Pete
I just took a look.
Pete
I just took a look.
Pete
I just took a look.
Pete
... but maybe it is from a different supplier so anything is possible...
