tires for a lift
Old Apr 15, 2011 | 11:31 AM
jdx45's Avatar
so i just measured my stock rims, there 18", so does that mean i dont have to buy rims to run 35s and can i still get spacers
Old Apr 15, 2011 | 12:13 PM
joh408's Avatar
Your stock rims are 18"? Pics please?
Old Apr 15, 2011 | 12:15 PM
jdx45's Avatar
alright, idk measured it from rim side to rim side, ill redo it and post the pic with the Measuring tape
Old Apr 15, 2011 | 12:43 PM
wandell's Avatar
The only OEM Ford wheels from 97-03 that were 18 inches were the Lightning wheels.
Old Apr 16, 2011 | 10:06 AM
jdx45's Avatar
well i have 18" and its not a lighting
Old Apr 16, 2011 | 10:25 AM
jdx45's Avatar
Uploaded with ImageShack.us
so what can i run with these 18's?
Old Apr 16, 2011 | 12:04 PM
Buxton91's Avatar
Those look like the lariat 17's. What does the metric tire size read?
Old Apr 16, 2011 | 12:12 PM
jdx45's Avatar
idk id have to look. but why?
Old Apr 16, 2011 | 12:17 PM
Buxton91's Avatar
The last number will tell you what size your wheels are. If you measure from inside the wheel lip to inside the lip on the other side it will give you a more accurate reading also. I'm pretty sure those are 17's though.
Old Apr 16, 2011 | 01:40 PM
wandell's Avatar
THose look like the OEM 17x7.5 inch wheels from what I can tell. The problem is you are measuring the outter edge of the wheel, not where the bead sits.
Old Apr 16, 2011 | 03:06 PM
Buxton91's Avatar
x2
Old Apr 17, 2011 | 10:45 AM
jdx45's Avatar
would it be recommended to get a leveling kit with a 6in lift? i was thinkin 2in,
Old May 5, 2011 | 10:21 AM
jdx45's Avatar
bump
Old May 5, 2011 | 12:39 PM
wandell's Avatar
You don't need a leveling kit. Your front ride height is adjustable by the amount of preload on the torsion bars.
Old May 10, 2011 | 11:03 AM
jdx45's Avatar
okay, but should i? or should i just get a body, id like to have 7 mayb 8in of a lift
