What size hose for bleeder valves?
Old Apr 8, 2011 | 12:00 PM
NacsMXer's Avatar
I have a 1999 F-150 with 4 wheel discs. I want to bleed my brakes.
Anybody know what size hose I need to fit snugly over the bleeder valves?
Thanks a lot.
Old Apr 8, 2011 | 12:22 PM
mkosu04's Avatar
probably like 1/8" ID hose will work. The bleeder valves are usually a bit bigger than that so it should fit on snugly.
Old Apr 8, 2011 | 12:33 PM
alfack's Avatar
If you want to do it another way, check out the speed bleeder screws with the valves in them. No hose necessary.
Old Apr 8, 2011 | 11:43 PM
NacsMXer's Avatar
Thanks guys. You sure on the 1/8" hose? I want to get the right size when I go to the store.
I'm actually going to be bleeding them/flushing the fluid with a 60cc syringe and a piece of hose hooked up to the bleeder valve, so a snug fit is preferable for a better seal. I have a Mityvac vacuum bleeder and the syringe works 10X better in terms of pure suction power and ease of use.
Just need to get the right size hose....let me know if 1/8" ID hose is the right one if you could. Thanks a lot.
