Wheel Fitment ?
Old Apr 7, 2011 | 10:49 AM
mxzeatr's Avatar
Wheel Fitment ?
Hey Guys,
New to the aftermarket wheel scene. But I fell into a 'deal' on a set of rims last night that I bought trusting that the owner knew what he was talking about.
They are 17x8 Motoring Rockers. Ford Bolt Pattern, he bought them for the tires that were on them (315/70-17's) and they were on the guys F150 that he bought them from, so I'm certain they'll fit but just looking for some backing on that.
There is a marking on the area where the wheel meets the hub that says +25, I'm assuming thats offset/backspacing? Maybe I'm wrong. I'd like to get them cleaned up tonight, so can get pictures if needed.
I'm running 275/70-17's on my 06 with 1.5" (2" actual measured) leveling kit.
Are they going to fit close to the same as stock?
Old Apr 7, 2011 | 12:07 PM
rrozell's Avatar
Bs is 5.65" or close to on that 8 inch rim with +25 offset. Lug pattern should be 6x135 if that helps
Old Apr 7, 2011 | 12:15 PM
mxzeatr's Avatar
Do you happen to know what the stock wheels BS is? Thats my concern.
The lug pattern is stamped on the wheel 6x135, so I knew they'd work that way, just a bit concerned about where the tires will be compared to where they are now...With stock wheels that is.
Old Apr 7, 2011 | 12:22 PM
rrozell's Avatar
stock rims (17 & 18)7.5 inches wide with 5.5 inches of backspacing
Old Apr 7, 2011 | 12:33 PM
mxzeatr's Avatar
Oh crap, I thought the stock rims were 8" wide as well.
Shouldn't matter for the tires though I don't think.
So they should fit really close to stock if I'm understanding this properly?
Thank you for the help!
Old Apr 7, 2011 | 12:46 PM
wandell's Avatar
If the wheels are 8 inches wide with 5.6 inches of BS, a 315/70-17 (35x12.50) will fit a 4x4 with a leveling kit. But it will be very tight and you may have to do some minor trimming.
Old Apr 7, 2011 | 12:50 PM
mxzeatr's Avatar
Thanks for the info.
But I'm going to run MY tires (that was a background story) which are 275/70-17 with the 1.5" AS level.
I just want to know if they'll be the same as stock, or very close to it as far as where they ride in the wheel wells.
Old Apr 7, 2011 | 12:51 PM
rrozell's Avatar
7.5" to 8" is not going to make a differnce on if the tires will fit.
Old Apr 7, 2011 | 01:02 PM
These are 315x70x17 BFG's on 17x8 wheels with 5.5 inches of BS, I had no rubbing with these wheels.
Old Apr 7, 2011 | 01:04 PM
mxzeatr's Avatar
Thanks.
So with similar backspacing and just a bit wider wheel, they aren't going to stick out/in further then stock correct? Thats really what I'm looking for.
Old Apr 7, 2011 | 01:09 PM
They'll stick out only about 1/2 inch more then stock.
Old Apr 7, 2011 | 01:23 PM
mxzeatr's Avatar
Barely noticeable then, thats what I was hoping for (if not the same). I would have done some of this research before buying the wheels, but for 100.00 w/locking lug nuts etc...I really couldn't pass it up to ask questions first! LOL
Thanks for the help. Hope to get them on this weekend, I'll snag a pic.
