will -12 offset work with 6" lift?
Old Apr 4, 2011 | 09:45 PM
whitelariat4x4's Avatar
Question will -12 offset work with 6" lift?
Hello all, i have new 2010 f150 xlt and i want to put on 6" rough country suspension lift (due to cost) and I want to put 35x12.5 tires either toyo open country or nitto trail grapplers. the issue that im running into is that roungh country's website says that i have to use a 8 inch wide wheel but i cant find any 8" ones that i like. but i have found 9" wide wheels with -12 offset and i am wondering if that would work with the 6" lift without any rubbing or trimming?? thanks a lot guys!
Old Apr 5, 2011 | 07:08 AM
Big_Smokey's Avatar
id say they mean run at least an 8 inch wide wheel. Most with the lifts are doing negative offset wheels at least 9 " wide. May touch some plastic a little bit, but nothing serious
Old Apr 5, 2011 | 11:06 AM
rrozell's Avatar
Repends on what backspacing is needed. You can run a 10" rim if you have they same bs as the 8" rim. My skyjacker kit requires a 4.5 bs. I bought a 9 inch rim with -12 offset (4.5 bs). It will work fine. Just will push rim out a little futher than 8 inch rim with say offset, 1" to be exact.
Old Apr 5, 2011 | 05:45 PM
Griff D's Avatar
I have that kit on my 2010 running 35x12.50/20 mud grapplers on a 20x10 incubus crushers with a -12 offset. they clear fine and i have no issues with rubbing
Old Apr 5, 2011 | 06:47 PM
thanks guys, griff D, do you have any other pictures of your truck so i can see how much they stick out? i can't tell much from the little one in your sig. thanks!
Old Apr 5, 2011 | 06:53 PM
Griff D's Avatar
Yea look in my album I have a couple in there. If not good enough i'll put some more up for ya
Old Apr 5, 2011 | 07:48 PM
Desert Dawg's Avatar
I went with -12mm offset on a 9 inch wide wheel with 4.5 inches of backspacing with a 4-inch lift and had no problems.
Old Apr 5, 2011 | 07:54 PM
08FX4's Avatar
I've got 20x10 Diamo 17K with a -12mm offset and 35/12.50/20 Trail Grapplers. I had to do some trimming to keep them from rubbing and they do stick out quite a bit but I love the stance.
Old Apr 5, 2011 | 08:23 PM
Griff D's Avatar
yea thats what my truck sits like except i didn't have to trim anything. good looking truck you got there by the way
Old Apr 5, 2011 | 08:42 PM
08FX4's Avatar
Thanks. Your truck looks good as well.
By the way..... are you sure the wheels you have are 20x10? When I was looking for wheels the Crushers were one of the wheels that I liked but I ruled them out because they couldn't be ordered in a 20x10. I'm assuming your wheels are actually 20x9 and that's why you didn't have to trim anything.
Old Apr 5, 2011 | 08:49 PM
Griff D's Avatar
They very well could be the box said 20x10 but they could be 20x9 they were ordered in a shipment when i was doing a lift on a customers truck and he didn't want them so i put them on because i liked them lol
Old Apr 5, 2011 | 09:00 PM
op01jre's Avatar
6" Lift with 35x12.50 Toyo MT with 20x10 XD monters -12 offset with no rubbing...no trimming...all good.
Old Apr 5, 2011 | 10:31 PM
08FX4's Avatar
Lol. Either way they look great on your truck!
Old Apr 5, 2011 | 10:47 PM
Griff D's Avatar
Thank you
Old Apr 6, 2011 | 03:28 PM
Nice! this is the look im looking for. thanks guys! Now i just have to decide between tires. Nitto trail grapplers or toyo open country mt. any suggestions?
