To all with XD monsters
Old Mar 31, 2011 | 11:20 PM
dilloncawthon's Avatar
Originally Posted by SAWMAN556
If I don't have any vibration issues, do I need the rings?
well if you have no issues then i guess not. whomever put your tires on did a good job centering them then. monsters are hub centric wheels so they are supposed to need the right size hub ring to make them fit snug on the hub. you may need them if you ever take your wheels off and put them back on.
Old Apr 1, 2011 | 03:03 AM
SAWMAN556's Avatar
I called the company I bought the wheels from, they are shipping me the correct ones. I might not need them but I will feel better knowing they're on there.
Old Apr 3, 2011 | 04:40 PM
BLACKOUT FX4's Avatar
What do these rings look like and where do they install? I dont know if my wheels have them and i do have a slight vibration in the 2 rear wheels.. Maybe I dont have them installed?
Update:
I just found the 4 green rings on the shelf in my garage.. I guess I need to install them!!
Old Apr 3, 2011 | 04:45 PM
WoW! I just installed them and the vibration is gone.. I cant believe I overlooked them when I bought the wheels!
Old Apr 4, 2011 | 02:48 AM
haha yep that is what the rings are for. to center the wheel.
Old Dec 21, 2011 | 11:04 AM
Damn Dirty Ape's Avatar
How about getting black and dark reddish rings with them, then which one?
Old Dec 21, 2011 | 02:34 PM
Big_Smokey's Avatar
you are going to have to find out which color is for your truck. Im guessing my what ive read each color goes to a certain make truck. Looks like green is the magic color. You will have to call the manufacturer to figure that out.
Old Dec 21, 2011 | 03:23 PM
BLUEforLIFE's Avatar
BLACKOUT - were do these rings go? im thinking i dont have them installed as well. I.ve taken my wheels off to clean them and didnt notice any ring.
Does anyone have a pic for ref?
thanks
Old Dec 21, 2011 | 04:05 PM
and they just have a form to submit with the 2-3 day turnaround time, no phone #.
Old Dec 21, 2011 | 06:11 PM
thanks
the hole that is through the center of your wheels, the ring goes inside that hole to make the diameter of the hole smaller so that the wheels center themselves on the hub. the hub being the part of the truck on the axle that goes through the big hole in the center of the wheel.
Old Dec 22, 2011 | 03:10 PM
Thanks dillon! - i.ll have to check now.
Old Dec 22, 2011 | 03:26 PM
rllackey28's Avatar
And one of the biggest reasons why you need the rings is that it takes stress off of the lug bolts and makes the hub load bearing. Without it all loads (dynamic and static) are taken by the lug bolts. Only a matter of time before the lug bolts take a jolt and snap.
Old Dec 22, 2011 | 03:29 PM
rllackey28's Avatar
Been over a year since I've looked at my rings but memory tells me that the I.D. of the rings are different to fit the different hubs since Monsters have two bolt patterns. The O.D. is the same.
The quickest way to figure out which one you need is to pull the center cap off your OEM rims and measure the hub diameter and compare it to your I.D. of the rings or to pull the wheel completely and try each ring.
Old Dec 22, 2011 | 05:43 PM
The rings mine came with are blue. Hmm.
Old Dec 22, 2011 | 05:58 PM
To answer my question, it was the BLUE ring. Boxes came with deep red and blue. RED is for Chevy Dodge and Blue for Ford.
New colors in the boxes I guess.
