Help with final decision
I'm running 275/60/20 on stock wheels. That will only be about an inch taller than mine and your current set up so I doubt you will have any problems assuming you have a level. It is possible to run up to a 35" tire on stock wheels with a level, the width is usually the problem with stocks and a 275/65/20 is roughly a 34 x 11.
