2006 F-150 4x4 ABS Light On
Old 03-04-2011, 12:19 AM
Jhall0125's Avatar
Hello, I started up my truck last week and my ABS light went solid and has not went off. I have pulled the battery cables to reset the computer and could only find 2 fuses relating to ABS and they were good. I know I need to get the codes read but I cannot locate the front ABS sensors or rear anyone have any pictures of the location and also any trouble shooting ideas?? Thanks for your help.
Old 03-04-2011, 12:33 AM
Jhall0125's Avatar
Also some more information, sometimes when I hit the brake it feels like my abs kicks in for a minute then stops for no reason. Also is there vacuum lines running to the hubs in front?
Old 03-16-2011, 10:57 PM
muddy99's Avatar
i dont know if this help but my truck is a 99f150 and my abs light started comming on when i barked the tires on a start then it started comming on for no reason at all then stayed on what fixed mine is the break fluid was low i know really weird but it fixed so you might want to check the fluid lvl... and the sensor on the front should be tied into the bearing housing on the front spindle i think it's all one piece but not sure if it comes off take the tire off to find it... hope this helps
Old 03-17-2011, 06:56 AM
kingfish51's Avatar
Yes there should be vacuum lines to the front hub. They unlock the hub when not in 4x4. Should not have any affect on ABS.
Quick Reply: 2006 F-150 4x4 ABS Light On
