295/70/18 on 18x9 rim with 5"bs??
im lookin at a 295/70/18 which when calculated came out as a 34.3x11.6x18, iim also lookin at a rim thats a 18x9, with 5" bs. will this combo work on an 2008 f-150, i know there will be trimming, but other then trimming the front valence, will there be any other problems? thanks
i saw ur gallery pictures, what about flexin, and turning how do they responed in differnt postions, do the tires rub any, idk if that .71 would make it rub or not, it looked pretty tight with ur hand between the inner fender and tire?
Almost 3/4 inch could make a huge difference. Also, do you have a 4x4 or 4x2? Leveling kit?
I like the stance, I notice on my truck the inner fender is plastic so it would be a easy trim but its the outside bottom corner near the door, if that makes since, if it clears that corner without being trimed, think I'm good to go on getting that tire size, if it requires minor tiriming then I'm not quite sure yet how to trim the corner down, I'm lookin at the trail grapple also .
