New Rims and Tires....(pics encouraged)
Old Jan 19, 2011 | 04:31 PM
CaliKid's Avatar
Since i believe i am not the only one that had to go through worrying about if a particular wheel tire combo would work or not i figured i would share the experience. Been looking for months knowing i wanted a more aggressive look for my truck and finally got what was needed (if this sounds like what you want keep reading). Gonna go through a few basics things that most people new to the world of an f150 would like to know by using the search feature in the top right hand corner.
Truck: 08 f150 screw 2wd
Leveling Kit: 2.5in Hell Bent Steel (off ebay)
Usually between 1.5-2.5 inches in order to raise the front end of the body to add extra clearance, typically bolted directly onto the factor springs and should only take a shop 1-2hrs to complete. This allows 2wd trucks to fit a wheel measuring 33x12.5 and 35x12.5 for 4wd trucks due to its added stock height. For the cost no more than $150 for labor and $70 for the kit itself. My total leveling kit cost me $280 with the alignment. Any more than that you should find a better deal.
Tires: 33x12.5x20 Nitto Mud Grapplers (discount tires)
Pros: look bad ***, sound great if you dont mind the tire hum like myself, and claimed to be great on and off road.
Cons: expensive, but what MT tire isnt....you get what you pay for.
Questionable: I have only driven 20 miles as of now, so tread life i have learned can be anywhere from 25,000 ( hard to believe) to 60,000 and still running ( also hard to believe). what it looks like if you maintain your alignment and dont live where the road temp reaches 120 F then you should expect around 30-50k depending how and where you drive.
Rims: 20x9 +18 offset XD Monsters (discount tires)
Top rim in my opinion and looks solid on just about any tire. Took me months to figure out the correct offset that i needed after endlessly searching this forum. So to give me the most optimal look i went with the +18. Gave me almost 2 inches of tire sticking out past the frame and enough clearance from the control arm/ plastic valance where i have absolutely no rubbing what so ever.
Offset/Backspacing:
IF YOU ARE QUESTIONING IF YOUR WHEEL WILL FIT. CHANCE IS IT WILL. If a +18 offset or 5.71in backspacing with a mud grappler fits on a 2wd leveled truck you will have no problem with another tire that is no more than 33x12.5 on a 9 inch rim. If you begin going into the Negative offset you may have to trim some plastic.
So offset and backspacing are EXACTLY the same thing. They are just a different measurement to describe the way that your rim will stick out or tuck in the fender depending on the look you want. Below is a great pic representing the view. And a website that will convert backspacing to offset with your specific wheel width.
https://www.rsracing.com/tech-wheel.html
Total with mounting and balancing and new bands for my tmps sensor i walked out of discount tire paying $2,650 for the wheels/tires just to give you an idea on their pricing.
Hope someone out there finds this thread somewhat helpful, below are some pics. Keep em coming...
Old Jan 19, 2011 | 04:43 PM
05supercrew's Avatar
Nice set up.
Old Jan 19, 2011 | 06:30 PM
speedyturtle's Avatar
2,650 for just wheels tires mounting balancing and tpms sensors??
Old Jan 19, 2011 | 08:52 PM
mazeone's Avatar
Nice post. It's nice to see you share all that information w/ those of us still window shopping. Everytime I think I have it figured out I feel like I go back to square one. I was set on Mamba 2 18's w/ BFG's now I'm thinking 20" xd's w/ coopers...
Old Jan 19, 2011 | 09:11 PM
That looks great man!
Old Jan 19, 2011 | 09:37 PM
rllackey28's Avatar
Really nice but I would get rid of the chrome since you have black rims now.
Old Jan 19, 2011 | 09:41 PM
Fordfanatic101's Avatar
Truck looks sick what part of Cali you from?
Old Jan 19, 2011 | 10:10 PM
RhondaRocks's Avatar
Looks great! I'm going back and forth with my final 5 I have narrowed down. This thread will definately help me a great deal, thanks!!
Rhonda
Old Jan 20, 2011 | 03:21 AM
CaliKid's Avatar
thanks guys, figured there would be a few ppl that would benefit. Currently down in san diego and rllackey thats next month. I plan on upgrading to a dual side exit exhaust and black rear and front bumpers...hopefully if i can find them somewhere
Old Jan 27, 2011 | 08:09 PM
mccullin's Avatar
Looks great. I am looking to put on a new wheel tire combo on my 2001 Screw and this info will help.
Old Jan 28, 2011 | 03:54 PM
Derrick@TireRack's Avatar
Former Sponsor
Good looking truck!!
Old Feb 2, 2011 | 06:25 PM
M.Veal's Avatar
ok, so i have a 07 fx4. I installed a 2.5" HBS leveling kit last weekend, i was told by quite a few people i could run 35x12.50 18's on my stock wheels, so i went ahead and ordered a set of nitto mud grapplers, went today to have them mounted and they will not fit, they hit the upper a-arm, so now it is either spacers or new wheels....i am thinking about these
the tire guy told me i need a +25 offset....is this correct?
Old Feb 2, 2011 | 10:23 PM
wandell's Avatar
A lot of members run 35x12.50's on leveled 4x4 with the stock wheels, but a lot of them rub the control arms at full steering lock. A MT with aggressive sidewall lugs will make this worse.
If you use an aftermarket wheel, you need an 8 inch wide wheel with 5.5 inches of backspacing.
Old Feb 3, 2011 | 09:00 PM
M.Veal's Avatar
that was just the thing, at full lock i didnt hit anywhere......i just could not rotate the wheel cause the tire lugs were on the a-arm. He told me to order 18x9's with a +25 offset, is anyone out there running this setup or do i just need to go ahead and cancel the order for the wheels until i find out exactly.
Old Feb 4, 2011 | 12:39 AM
HessFx4's Avatar
I'm running 35x12.50 on stock wheels onLy on rubs at full lock, your Grapplers must be wider than my trail Grapplers... But I'm wanting new rims myself, cause I hate it rubbing!
