Negative Offset question..
Old Jan 11, 2011 | 03:44 PM
kaaRN's Avatar
I have a 2010 f150 2wd.. I have a level kit with 1" blocks on the back... I am wanting to put BFG's A/T KO 285/70R17 with the Eagle Alloy series 079 17x9 wheel... The offset is -12... Tire place is saying it wont work anyone have anythin close to this?? I dont mind cutting the plastic under there..
Thanks Kendra
Old Jan 11, 2011 | 09:15 PM
bigbear08's Avatar
I recently put a Rough Country leveling kit on my 2008 F150 4x4. The kit included 2 1/2 in. front spacers and 1 in. rear blocks with shocks. The truck came with 17 in. wheels. I planned to just buy aftermarket 17 in. wheels. I went to Discount Tire and purchased 20x8.5 liquid metal magma wheels and 305/55/20 Nitto Trail Grapplers. The cost was more, but it was well worth it. The back spacing on my wheels is 25BMM according to Discount Tires. They stated it was approximately 5.71. I have no rubbing even at full lock. maybe this helps.
Old Jan 12, 2011 | 12:20 PM
Derrick@TireRack's Avatar
Former Sponsor
I would say it will fit. Going to be tight and you might have to do the trimming on the plastic, but should work. I would suggest doing a test for if you want to be 100% sure you will like it. Sometimes just ordering 1 wheel and tire and test fitting is worth it just to make sure you are going to be happy with it. as long as you don't drive on it, and end up not liking it, you should be able to return it and not have it cost you a fortune. But should work.
