Disc vs Drum ?
Disc vs Drum ?
I blew the rear out of my 01...I can't locate another used one with disc brakes anywhere BUT I've found a nice one with drums. Am I losing a lot of stopping power by changing over or should I stick with the discs?
Will the disc master cylinder work with a drum setup?
i am not certain about your master cylinder compatability, but i think it will not work due to the fact that disc brakes and drum brakes use different amounts of fluid to apply the brakes which is why they come with different volumes and diameters of the pistons internally. a disc brake will use more fluid due to a larger piston diameter compared to a drum cylinders smaller piston diameters.
