stock rim tire size
Old Jan 3, 2011 | 03:19 AM
panda24619's Avatar
so i think im getting good year duratrac tires. 315 75 16 tires. then get rims later. im thinking black steel procomp 52. 4" back spacing. is that too much? i only like them cause they are cheap. wheel spacers i can always get too, but should i look for a wheel with a smaller back spacing?
Old Jan 3, 2011 | 10:32 AM
mdhawkin's Avatar
Are you wanting the procomps to go with the 16" wheel? If so I am guessing your best bet for the least amount of rubbing would that will still work with the 315 would be this one: http://www.procompusa.com/prodDetail...21&plID=100347
Old Jan 3, 2011 | 12:40 PM
wandell's Avatar
I'm not convinced that 35's will fit with those Pro Comps. I'm sure they won't fit with the wheel he chose. At least not without more lift or a sawsall.
Old Jan 3, 2011 | 02:21 PM
panda24619's Avatar
well i am lifting the rear 3 inches. and i cant decide between the 52 or 152. but i like the 52s more. and i am willing to trim a little bit. and theres a guy on expedition forum that fits 315s with no lift. but its his winter set up.
Old Jan 3, 2011 | 02:52 PM
mdhawkin's Avatar
It was the lesser of the evils. Bottom line the truck needs to go up, keep factory wheels, or go with a smaller tire.
Old Jan 3, 2011 | 05:41 PM
panda24619's Avatar
ill just get a body lift too. either 2 or 3". not too much on this site i saw and ill do it my self. so if i did that then the 315s will fit better?
Old Jan 3, 2011 | 09:38 PM
wandell's Avatar
Yes, if you install a 3 inch body lift you will be able to fit a 35x12.50 tire with an 8, 9 or 10 inch wide wheel.
Old Jan 3, 2011 | 10:05 PM
panda24619's Avatar
okay so for now i should just stick with 285s still i get a body lift. but i want taller tires. i just see what i can get once i get my spacers.
