Emergency brake/parking brake adjustment done...OOPS.
So, I decided to adjust my parking brake tonight, because I use the parking brake all the time, and I was tired of having one that would hold the truck if it were on a completely level surface, and the transmission was in Park. Also I had a nice heated building I could drive into to work on it.
Driver's side went fine, turned the wheel about 3/4 turn, and put the plug back in.
Passenger side was a little more hassle, the hole is in a poor position to get at it, but such is life. A shorter screwdriver would have helped, I think. Got it adjusted also, about the same amount, and put the plug back ... $#it! I pushed it all the way in!
So, the question is, do I need to take the wheel/rotor off to retrieve the plug, or should I just go to the dealer tomorrow and get a new one, and forget about the one in there?
I can't really imagine it doing any damage to anything, the absolute worst I can picture is it melting and making a bad smell.
Any thoughts?
Oh, and I need to adjust some more, as it still is a bit weak. Rolls a foot before binding up on my driveway, which has a fairly gentle slope.
Any thoughts?
The hardware does need some cleaning, it was cranky about adjusting, so a thorough cleaning before adjustment will do it good.
Just being lazy, that's all.
