How do I put air in the tires?
Old Dec 7, 2010 | 07:28 PM
nhadden's Avatar
Sound easy? The mechanic at the Ford Dealership in Bay City Michigan couldn't figure it our either.
There is a solid metal cap on the end of the valve stem on my 2010 F150 pick up. The tires are low and need air.
What gives?
Anyone have an idea here?
Old Dec 7, 2010 | 07:58 PM
papajohn's Avatar
pics would help???
Old Dec 7, 2010 | 08:11 PM
jjntj2003's Avatar
gotta see pics of this!
Old Dec 7, 2010 | 09:10 PM
KazK's Avatar
Do what...
Old Dec 8, 2010 | 06:49 AM
shotgunz's Avatar
This is going to be fun.
Old Dec 8, 2010 | 07:17 AM
blackedoutV6's Avatar
hmmmm
Old Dec 8, 2010 | 08:02 AM
DarkShadowSTX's Avatar
Old Dec 8, 2010 | 09:07 AM
Go to a gas station that has air pumps for tires. Many gas stations offer free or low-priced air to put in your tires.
2.
Remove the cap from the valve stem on the tire that you will be putting air into. Leave the cap in a place where it cannot roll away.
3.
Place the top of the air pump firmly over your tire's valve stem, hard enough so that you do not hear any air escaping.
4.
Continue to add air until the tire looks full, then remove the air pump from the tire's valve stem.
5.
Put a tire gauge firmly onto the tire's valve stem in order to read the tire's air pressure. If the air pressure is below the vehicle manufacturer's recommended tire air pressure level, then you will need to add more air to the tire.
6.
Repeat the process of adding air and checking the tire's air pressure until it reaches the manufacturer's recommended level.
7.
Replace the cap on the valve stem.
8.
Add air to all four tires, if necessary. Having the same tire air pressure in all four tires will ensure smooth ride quality and potential fuel savings.
Old Dec 8, 2010 | 09:23 AM
I think your post should go to the How-To section KRC.
Don't do that. I've seen a lady explode her tire trying to fill it with too much air at a gas station. LMAO.
Old Dec 8, 2010 | 09:32 AM
MGDfan's Avatar
^^ Yep!
A finer, more concise Technical Article has not been written! This will earn ya yer TAC title, KRC!
I would add one item:
9.If the tire blows up, you have added too much air. Adjust filling time accordingly.
MGD
Old Dec 8, 2010 | 10:08 AM
What gives?
A mechanic? That's your problem, they do not know anything about tires. Go to Discount Tire, one of the kids will take care of it.
Old Dec 8, 2010 | 10:30 AM
mdhawkin's Avatar
I think your post should go to the How-To section KRC. :lol
Why not just post this link LOL: http://www.ehow.com/how_2052908_put-air-tire.html
Old Dec 8, 2010 | 11:01 AM
jpf150's Avatar
at this thread.
Old Dec 8, 2010 | 07:03 PM
onewheelneil's Avatar
Just bend down,put your lips around the valve stem and blow really hard until you here the tire beep 3 times.Thats how you have to do it on the 09 and up models.
Old Dec 8, 2010 | 07:10 PM
Jon Bourget's Avatar
Make sure all the Summer air is replaced with Winter air to ensure safer winter driving.
