Wheel Offset Questions
The difference between the 2 offsets are 1.18 inches. Depending on what look your going for and how much you want them to stick out, I would say the +18 would keep the wheel closer to the stock position, which will help keep the side of the truck cleaner. The wider stance that the -12 offset will give, does have a sweet look, but does also allow more mud and water to be flipped up on the side of the truck. The XD Monster is a sweet wheel. It was that or the new Enkei GRAB6 for me. I went with the Enkei and love it. Here are some links if you want to see both.
Enkei GRAB6:
http://www.tirerack.com/a.jsp?a=BZ1&...=Black+Painted
XD Monster:
Let me know if you have any questions.
Derrick
Enkei GRAB6:
XD Monster:
Derrick
Enkei GRAB6:
XD Monster:
Derrick
Enkei GRAB6:
XD Monster:
Derrick
The Stock offset on the 03 Ford f150 wheels would be a +14. Every 10mm = .39". The higher up in the number you go will put the wheel closer to the frame and lower or negetive offsets will push the wheels out. The +18 will be .16" further in toward the frame from the stock wheels and the -12 offset will be 1.02" further out from the stock set up.
We do have the XD Monster available in a 18x9 with a +18 offset.
Derrick
Derrick
