Mamba M2's
Mamba M2's
I'm looking at getting these in an 18X9 for my 05 4wd. What is the widest and tallest tire I can go with without having to cut. Here are the specs:
18X9
6" BS
+25mm offset
I'd like the tires to stick out just a bit but I'm afraid the backspacing on these wheels won't let me achieve that. I am planning on adding a leveling kit as well..likely 2".
Any thoughts?
18X9
6" BS
+25mm offset
Any thoughts?
with a leveling kit and an 18x9 rim you should look for a rim with 5" of backspacing and a +18mm offset this will stick out of the wheel wells about an inch on each side approx. You should be able to fit a 33" tall tire with that combo, or a 35" tire on stock rims. Wandell or someone else will give you an accurate answer.
Cheers
Cheers
18X9
6" BS
+25mm offset
Any thoughts?
18X9
6" BS
+25mm offset
Any thoughts?
Cheers
Cheers
Either size will look good, but the 5" bs wheel will stick out 3/4" further than the other.
KR-Texas
