22's
22's
i found the wheels i want for my 150 and they say they're for a rwd truck/suv 5 lug but they dont say if they'll fit 5 on 135 or will any 5 lug wheel fit? here is the listing: http://www.customwheelsdirect.com/ht...l.php?id=71002
i have the same style 22 and thy stated rwd as well as long as the bolt pattern is 5x135 they will fit and ride very nice i currently have kuhmo 305/40/22 and if i make a hard U turn they rub but not in reverse...simply stated i dont let the wife drive, or park for that matter. ive never had a problem with balancing or anything like that i suppose you could use a spacer for a wider look but as far as a lift they wont do much they are almost same size as the stocks just a bigger rim, so your speedo will remain the same. handeling is fantastic i admit turning at high speeds is a dramatic difference. i hope this helps GL
