Vibration comes & goes......
Old Aug 10, 2010 | 08:30 AM
BLUE Dog's Avatar
Hey guys,
I have through alot of post on vibrations over the last couple days about this. I have already checked the tie rods and no play. It is weird I seem to notice it around 40-55mph and then eventually it goes away. It does not do it everyday either. I am leaning towards wheel bearing & maybe a pad caliper.
Any thoughts?
Old May 4, 2011 | 09:46 PM
aneff's Avatar
I am having a similar problem. Had the tires (new)/wheels rebalanced twice, but still have the same problem you described. What did you find? What was the fix?
Old May 5, 2011 | 11:21 AM
kingfish51's Avatar
Check for e-brake problems. It is a known issue that when they rub for whatever reason, it generates heat and vibration.
Old May 23, 2011 | 09:57 PM
aneff's Avatar
FYI. It appears not to be vibrating when the outdoor temp is over 55/60. I am going to get the shocks replaced (65,000 on truck/shocks) to see if that helps.
