time for new front rotors, need help
Old Jul 27, 2010 | 03:16 PM
luckythirteen13's Avatar
well my front brakes are warped. even the slightest application of the pedle causes bad shaking, violent shaking at freeway speeds. all bushings are good and there is no play in the steering system. i have done many brake jobs are fox body mustangs but the truck is all new to me. i have a 07 f150 2WD. im getting conflicting info such as the ability to reuse the crown nut as well as the bearings. i looked for a haynes manual but could find one at the local parts store. so here are my questions:
1. can the crown nut be reused?
2. do i need to buy new bearings?
3. on mustangs you torque the nut to a certain in. pounds but for the trucks im hearing 295ft/pounds. can some one give me some insight here?
4. do i need to replace the pads?
5. is this a good site to buy from and if not, what is a good site?
http://brakeperformance.com/site/bra...1410&ad=direct
im thinking of getting the premium ones so i get free brake pads, good idea or no?
thanks guys/gals. and if there is a write up, id love to know about it.
Old Jul 27, 2010 | 06:05 PM
305f150's Avatar
Im also looking to get new rotors, I have always been told that dimple/ holes make for a whole ton of brake dust. If you get them let me know how they go.
Old Jul 27, 2010 | 06:43 PM
aqua-holic's Avatar
Yep , reuse the nut. When I did mine ,someone here said to lay it flat on the ground and lightly tap with hammer. Not sure it did anything but my brakes are perfect. Dealership even re-uses them. 295 ft lbs is right too. Defineatly, replace the pads ( do it right) get some Wagner Thermaquiets.
Old Jul 27, 2010 | 06:44 PM
Unless you are racing it, you do not want drilled rotors, slotted are ok, but not really needed. The bearings are built into the rotors on the 4x2, however, Centric makes a conversion hub. You then buy the bearings fo the 4x4. I replaced mine with Raybestos rotors about 63,000 miles ago and have no problems. I reused the nuts, they are secured with a cotter pin, so do not see the need for replacement. To get them off, you will need a huge deep socket. I think it was a 36 mm, maybe.
Old Jul 27, 2010 | 09:47 PM
awesome guys i really appreciate the info. you answered all my questions. looks like ill have to bite the bullet and buy a new torque wrench. mine only goes to 150ft/lbs. ive also read you cant push the brake fluid back up the line like you can on older cars because itll damage the abs system, is this true? seems like a lot of work to bleed the whole system just to replace rotors
if i dont need drilled/slotted rotors (which i cant argue with you), any links to just a standard replacement rotor? preferably to ones that are better then stock, dont need this happening again
is the part number i need qc1083 for the pads?
Old Jul 27, 2010 | 10:29 PM
I have repalced pads twice and rotors once. To get the caliper off I used a c-clamp and pushed the piston back. I have never had to bleed the brakes nor have I had an ABS problem. I don't open up the lines, so no need to bleed.
I would go with any name brand, Hawk, Raybestos, Wagner, just don't get the cheap Chinese off brands.
Old Jul 27, 2010 | 11:12 PM
x2mosg's Avatar
Might want to read this thread before you buy. At least a couple of guys have bought and installed these and are liking them so far. Worth a read.
https://www.f150online.com/forums/20...try-these.html
David
Old Jul 28, 2010 | 11:33 AM
David
sent the seller an email but looks like he only has 4wd stuff
Old Jul 28, 2010 | 11:59 AM
well just so i dont have to start a new brake thread ill ask here. what is the brake distribution on these trucks? seems like its 95% front, 5% rear
