rotors
Old Jul 12, 2010 | 03:18 PM
unclealan's Avatar
can't get my rotors off 2007 ford f-150
I have a 2007 ford F-150 XL 2 wheel drive V-8 4.6 and I can't get the front rotors off is there a trick or a special tool to get them off, Ford has not helped me at all.
Last edited by unclealan; Jul 12, 2010 at 03:26 PM. Reason: wanted to add more words
Old Jul 12, 2010 | 03:20 PM
NCSU_05_FX4's Avatar
http://www.youtube.com/watch?v=mtsTJCRljAs
- NCSU
Old Jul 12, 2010 | 03:48 PM
unclealan's Avatar
thanks
thank you we did not try that but we sure beat the heck out of it
Old Jul 12, 2010 | 04:18 PM
jgger's Avatar
2WD is one piece hub/rotor isn't it?
If so DON'T use the video info to get it off, take off the nut that holds the wheel bearing.
My 03 2WD is one piece.
Old Jul 19, 2010 | 10:03 AM
unclealan's Avatar
rotor
yes it is a 2 wheel drive, when we looked at one at the shop it said it came with all the rotor and hub assembley. Thank you
Old Jul 19, 2010 | 10:18 AM
There is a huge nut that holds the rotor on the 4x2. It requires a deep socket and if memory serves, it is a 36. Maybe between a 1 1/16 and a 1 1/4. To get to it, you remove a cotter pin and a retainer. Once you have the nut off, the rotor will practally fall off.
