Speedo Difference
Old May 7, 2010 | 01:13 AM
075SpdSTX's Avatar
Speedo Difference
So if I go from a 255/65/17 to a 265/70/17 how much of a difference do you think there would be from the speedo to actual speed?
Old May 7, 2010 | 01:21 AM
FASTFRANK's Avatar
5.2% - when your speedo shows 60 your actual speed will be 63.1
Here's a handy calculator for these calculations http://www.rimsntires.com/rt_specs.jsp
wisconsinFX4's Avatar
255/65/r17 revs/mile 671....265/70r17 638 revs/mile
Old May 7, 2010 | 01:44 AM
075SpdSTX's Avatar
Wow! That's more of a difference than I thought. Let me guess, the only way to correct this would be a programmer?
Old May 7, 2010 | 05:49 PM
FASTFRANK's Avatar
Actually a dealer may be able to reprogram your ECM for the new tire size. I've heard they have some limits but definitely worth looking into. Probably an hours labor at most - a lot less than a programmer would cost you.
Old May 7, 2010 | 05:59 PM
It's a lot less, yes, usually about $100, but that is money that could be put on a programmer that makes the truck run and shift like it should. plus, next time you change the tire size, you have it.
Old May 7, 2010 | 07:40 PM
dilloncawthon's Avatar
actually you're speedo might be correct now. the stock speedos are about 1-2mph fast, i wouldn't waste the money to fix it. unless of course you want to use this as an excuse to get a programmer lol
Old May 8, 2010 | 12:43 AM
075SpdSTX's Avatar
Well I must admit If there is a significant difference in speed than I may definitely want it corrected. If it's only a mile an hour than I could live with that. Plus, I'm not sure A programmer would be worth the money. I have heard of others with the V6 getting one but, I'm not sure I'd benefit as much having the man tran.
