Another "Stick Out" Question
#31
When comparing offset between two different wheels ad figuring out which one will stick out more it doesn’t matter where you measure from (inside or outside the lip) as long as you measure both rims the same way. The solution is in the difference in the two rim widths. Where they are measured from is irrelevant, the difference between the rim diameters/offset will be the same.
Lastly backspacing is a Stone Age way of measuring. It has too many variables. Offset is the only 100% accurate way of calculating where a wheel will sit in relation to the hub or in comparison to another rim. Offset is calculated off of the center of the rim (which will be in the same spot no matter where you measure the wheel diameter from). Measuring for offset eliminates a lot of variables that backspacing can’t.
And one more thing, if you want your argument taken seriously check your temper/ego at the door ad use math to prove your point. Math removes the variable that is human desire and agenda and eliminates opinion and replaces it with fact.
If you can’t show your work your theory is nothing but speculation.
Good luck
“One is only capable of understanding something as complex as ones self”
A monkey can’t comprehend the complexity that a human can and never will. It does not have the intelligence to understand something more complex than itself. This also takes place in species.
Try reading and understanding my post before constructing a reply. So far you have clearly not bee reading what I wrote……..or you don’t understand.
I've wasted enough time here. Clearly you are not willing to look at situations from more complex and different angles even if that may mean you improve your unerstanding of some situations.
Here's to you having an epiphany someday soon.
#32
Clearly I do.
Here we go with the rim lip ordeal again. I said that you can add 1" to the rim width (bead seat to bead seat) and figure backspacing from there. Since this doesn't work explain why I can take any given auto wheel manufacturers rim width/offset and come up with the exact backspacing they have listed? I never said it was the right way to do it. I said that's how you do it.
That's true. However the math you done earlier doesn't work.
I agree fully.
I don't have any temperament or ego issues.
Let's look at the steps required to compare the difference between a 17x7.5 with a +44mm offset and a 20x9 with a +18mm offset. One thing to remember here is since we are going to use offset for this calculation and not backspacing we have to work off the centerline of the wheel.
(1) Find the center of the 7.5" wheel: 7.5/2 = 3.75" = 95.25mm
(2) Subtract the offset since it's positive: 95.25mm - 44mm = 51.25mm from where the hub meets the wheel to the bead seat.
(3) Find the center of the 9" wheel: 9/2 = 4.5" = 114.3mm
(4) Subtract the offset since it's positive: 114.3mm - 18mm = 96.3mm from where the hub meets the wheel to the bead seat.
(5) Subtract step #2 from step #4 and you have your answer: 96.3mm - 51.25mm = 45.05mm = 1.77"
I fully understand and I completely read everything before I post.
In my opinion (and apparently in the opinion of others that have posted in this thread) you are the one that needs a little more understanding on this topic regardless of what you've done in the past.
Last I checked this isn't an English class and I didn't sign up for one.
And while we're on the topic of grammatical errors please see the above quotes.
Obviously you know you're right and I know I'm right so lets leave it at that.
It is an inconsistent measurement, some rims have bigger lips ad others smaller ones. That automatically removes it from the calculation because it is not a constant factor. Rim width is measured at the bead because it is a constant across all rims and is where the manufacturers measure their rims for width.
