4.5 backspacing...
Old Apr 4, 2010 | 02:28 AM
DRJ's Avatar
DRJ
Post 4.5 backspacing...
I am looking to purchase a new set of upper control arms and I found some info saying that I would need a maximum of 4.5" of backspace for a camburg setup. Now does this mean that I could fit my stock rims still? I know that the backspacing on stockers are 5.5" but the wording doesn't quite click, thanks in advance.
Old Apr 4, 2010 | 07:07 AM
90454SS's Avatar
If it says maximum then no nothing greater that 4.5" will fit. Stockers are out, this is the same as most lift kits out there.
Old Apr 4, 2010 | 02:02 PM
DRJ's Avatar
DRJ
so which way would be greater? 4.6 or 4.4?
Old Apr 4, 2010 | 02:08 PM
got556's Avatar
4.6 would be greater backspacing...pulling the edge of the wheel and sidewall of the tire closer to the arm. 4.4 would push it farther away. ETA: assuming the aftermarket wheel you go with is 9 inches....it's gonna be sticking out about 2" farther on the outside lip than a factory FX4 wheel (8" wide). So take that into account w/ rubbing issues, tires kicking up debris all over the side of your truck, etc.
Old Apr 5, 2010 | 02:34 PM
DRJ's Avatar
DRJ
got it, thanks guys
Old Apr 5, 2010 | 03:21 PM
AZFX4's Avatar
you could use stock wheels with spacers
