Need help with backspacing/offset
Old Mar 15, 2010 | 10:01 PM
buckshot85's Avatar
Question Need help with backspacing/offset
so i'm buying D Cepek FC-II with moto metal 18x9 but not sure which size to get. the tires are 12.9in wide even though they say 12.5....i dont want them to stick to far out but dont want rubbing which set up would be better????
backspacing= 4.53 offset= -12mm
backspacing=5.71 offset= 18mm
backspacing= 6.18 offset= 30mm
Your help would greatly be appreciated and photos if you have any.
Old Mar 15, 2010 | 10:06 PM
Tyler33's Avatar
+18 would be my vote. I have -12mm and my 12.4" tires stick out a good 2 inches. I get quite a few rocks thrown up from my tires. Pics in my gallery.
Old Mar 15, 2010 | 10:34 PM
buckshot85's Avatar
thanks i'll look into them then but i do think your set up looks great it's not to far out
Old Mar 15, 2010 | 10:43 PM
wandell's Avatar
A 9 inch wide wheel with 4.53 inches of BS will stick out about 2.5 inches farther than the stock wheels, 5.71 inches of BS will stick out about 1.21 inches farther than stock and 6.1 inches of BS will stick out about an inch farther than stock.
Old Mar 15, 2010 | 10:53 PM
hawg_man's Avatar
Since you have stock rims and tires.....
The tires alone with stick out roughly 1.5'' further than stock
Add the 1.5'' more for the width of the rims regardless of backspacing
I would go with the the 5.71 bs.
I am assuming you are leveling and going with 33's?
Last edited by hawg_man; Mar 15, 2010 at 10:56 PM. Reason: Dangit...he beat me again....
Old Mar 15, 2010 | 11:00 PM
buckshot85's Avatar
yes i have a 3in leveling kit with 1in add leaf
Old Mar 15, 2010 | 11:12 PM
AZFX4's Avatar
I have 5.71 +18 and I think they are perfect.
Old Mar 16, 2010 | 12:00 PM
wandell's Avatar
Also, don't go over 2.5 inches with a leveling kit. The 3 inch kits leave the ball joints at too severe of an angle to last.
