I think I'd like some tires that will fill in my wheel wells more...
Old Mar 10, 2010 | 08:23 PM
BrainDonor's Avatar
My summer rims: ATX Predators
Size: 17 x 8.5
Offset: 15
Back Spacing: 5.34
2009 F150 XLT 4x4. I don't have a lift.
What's the largest I can do without the tires rubbing?
What's the largest I can do with minimal rubbing?
I'd also like them to look rugged, but without the road noise that normally comes with rugged tires.
Not asking for much am I?
Thanks for any help you can provide.
Old Mar 10, 2010 | 09:02 PM
muliefever's Avatar
MMM.. 265/70/17...... I would say 285/70/17, but I am not 100% sure
Old Mar 10, 2010 | 09:14 PM
jdruzik's Avatar
Toyo has 17 inch tires that are 34.1 inches tall and with a leveling kit they do not rub and no trimming was required...
34x11.50 R17s, 34.1 inches tall and 11.6 inches wide...
Old Mar 10, 2010 | 10:34 PM
wandell's Avatar
I'd go with a 285/70-17 or 305/65-17.
Old Mar 10, 2010 | 10:43 PM
ford norseman's Avatar
I don't know if this helps, but I am currently running 265/70r17s on my 2wd with no rubbing problems. Your 4x4 should sit about 2 inches higher, so you should be able to clear significantly larger tires.
Old Mar 11, 2010 | 01:05 PM
I'd guess a 295x70x17. 33.5x12 Nitto makes these and so does Toyo. These may be close at stock height.
Old Mar 17, 2010 | 10:32 PM
BrainDonor's Avatar
What's the max I could do with a 1.5" AS front level kit?
Old Mar 17, 2010 | 10:40 PM
05crewzer's Avatar
thats what i was thinking. it will work.
Old Mar 17, 2010 | 10:43 PM
wandell's Avatar
With the rims you mentioned, I'd stick with a 305/65-17 (33x12.50) or a 295/70-17 (34x12.00) tire.
Old Mar 17, 2010 | 10:44 PM
05crewzer's Avatar
this is what i would say you could do with a 1.5 level. (with slight rubbing)
Old Mar 17, 2010 | 10:46 PM
BrainDonor's Avatar
what would I need to do to get something like these to fit?...rims and all?
Originally Posted by DeereGeff
I have 17" wheels on mine currently for the winter. They fit, but the rear caliper was too close to allow for stacking stick on wheel weights double high on the inside of the rim.:o
I may put my wheels/tires up for sale in a few weeks when I switch back to my 20's.
Here is a shot of my truck on the 17's and some 315/70/R17 Mickey Thompson MTZ's on them.
Old Mar 17, 2010 | 10:50 PM
05crewzer's Avatar
minumum 4" lift. 6 inch will definetly clear 35 and aftermarket rims. i'ld go with the 4".
or level and body lift would work.
Old Mar 17, 2010 | 10:59 PM
BrainDonor's Avatar
drat!
can't go that high because of my garage.
Old Mar 17, 2010 | 11:07 PM
DeereGeff's Avatar
I'm not sure what it would take as I already had the lift on my truck when I installed them.
According to Mickey Thompson's website, the 315/70R17's are 11.9" x 34.6"
http://www.mickeythompsontires.com/t...=BajaMTZRadial
The wheels are 17x9 with a -12 offset
Old Mar 17, 2010 | 11:28 PM
05crewzer's Avatar
drat!
true, 4" and 35's will not fit in most garages. they should make them bigger for people like us!
