Cant break rear drum loose
Finally the drum is off, I quit being easy on it and took a hammer to it. Now one of the shoes are cracked, the parking brake cable is broke, and the brake line broke. So i pretty much have to replace everything on that side. Oh and the drum has to be replaced too. But all is well. thanks for all the replys
OK good on the axles not bieng loose, but ya, you're bound to break a few things unfortunately- double edged sword. I've always periodically checked drums and in doing so grind down the lip so the next time it's easier, also scuffed the drum surface with sandpaper.
