Tire Options/Help
Old Jan 11, 2010 | 04:57 PM
triathlonrunner's Avatar
Tire Options/Help
Hey guys. Looking at new tires I see I see I have a lot of options. I drive a 99 f250 LD and will be most likely getting a leveling kit with the tires. I've been looking at mainly toyos, coopers and BFGs (265/75/16 or 285/75/16). I drive about 90% highway, but when i go offroad it is on my families farm for work purposes and I need good traction to not get stuck(2wd only ...). Anyways would a A/T tire be good enough for my purposes like the bfg at, cooper st, or toyo at? These would cost less also. Or would it be worth it to spend the extra say $50-75 more to get the m/t of each brand?
Thanks!
Also, I've read all over that 285s will fit on a 7.5 inch rim. I'm assuming this is true, but am not sure what size rim i have on my truck. I'm assuming it's a 7.5 inch rim. Does anyone know?
Thanks!
Old Jan 11, 2010 | 06:57 PM
Damon@tirerack's Avatar
Former Sponsor
Give me a call please. I'd be glad to help!
Old Jan 11, 2010 | 10:17 PM
wandell's Avatar
Your OEM wheels are either 16x7's or 17x7.5's. I'd go with a 265/75-16, 265/70-17 (32x10.50) or a 285/75-16, 285/70-17 (33x11.50).
Old Jan 11, 2010 | 11:06 PM
I'm pretty sure they are 16x7...could I put 285s on them? I'd rather 285s over 265s if I could fit them, but honestly in your opinion, would it make that much of a difference?
thanks
Old Jan 12, 2010 | 12:14 PM
wandell's Avatar
You can fit a 285/75-16, barely. In my opinion they look to "stuffed" on a stock 4x2. Now if you do add the leveling kit they will look much better.
Old Jan 20, 2010 | 05:55 PM
thanks....if i cant get the leveling kit im going to go with the 265s. they recommend a 7.5" rim for 265s and an 8" rim for 285s though...i can use a 7" rim right?
Old Jan 20, 2010 | 10:30 PM
wandell's Avatar
RIght.
